Rear rotor removal - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Brakes
Brakes Performance Brake Upgrades
Old 02-23-2007, 10:27 PM
03PoloBravada 03PoloBravada is offline
Rear rotor removal
Is there any special procedure to remove the rear rotors to replace them? Im just wondering cause of the drum style parking brake setup on the rotor. Thanks for any help.
Old 02-23-2007, 10:36 PM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
2006 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
Nothing fancy...you might have to cut a few retaining clips off of the lugs, but that should be all
If the rotor is stuck, you should use a slide hammer, with the hook in the vent slot on the side of the rotor, to free it
Just curious...why are you pulling them off
-Mike
AKA PROVY
Rock On!
Old 02-23-2007, 10:42 PM
Frostee's Avatar
Frostee Frostee is offline
NA NA NA
NA Other AWD
me and my pops used a 'persuader' when we needed to get them off. one was a real pain because of the lip on the inside.
When life hands you lemons, ask for tequila and salt, then call me over
Old 02-23-2007, 10:47 PM
MTPockets MTPockets is offline
You will smash the he!! out of the flimsy parking brake shoes if they've worn a ridge into the hat of the rotor. There is a star wheel adjuster to back off the shoes a bit for rotor removal.
Joel
Old 02-23-2007, 11:10 PM
PROSPHOTO's Avatar
Joel,
I don't think I've ever looked...Can you get to the adjuster on these with the rotor on
Have you seen these drum-in-hats score the hat to where the rotor will not come off...usually they stick to the hub assembly b/c of rust
-Mike
AKA PROVY
Rock On!
Old 02-23-2007, 11:37 PM
I've had it happen on other rear disk brake vehicles. Havent had to do my 2005's brakes yet. Usually there is a rubber plug covering the adjuster hole on the inside of the backing plates.
Joel
Old 02-23-2007, 11:44 PM
PROSPHOTO's Avatar
I just looked under my '06...no plug/access with the rotor on
-Mike
AKA PROVY
Rock On!
Old 02-24-2007, 12:23 AM
MrBigStuff MrBigStuff is offline
2005 Chevy TrailBlazer LS EXT
Summit White 4.2L I6 4X4
Access
Look carefully at the backing plate. It may have a relief stamped into it where the hole is located. If it does, then you have to punch/pry the slug out to access the adjuster. After the first access, you have to install a rubber plug. I've seen this done before on other newer cars I've owned. Seems to be a cost cutting measure. If they can save a dime, they will....
Old 02-24-2007, 12:42 AM
PROSPHOTO's Avatar
If you look at post #12 in this thread,
(thanks LMMJ)
...it doesn't look like there is any way to access the adjuster w/o removing the rotor
I actually appears that the adjuster is mounted to the backing plate like a rear wheel cylinder would be on a drum brake system
-Mike
AKA PROVY
Rock On!
Old 02-24-2007, 01:13 AM
Good call! I remember that pic from awhile back. Sure does look like no access thru the backing plate for that bad boy.
Joel
Similar Threads
Rear wiper problem ninesevens10 General 11 09-23-2013 01:55 PM
A couple audio questions.... (factory XM, and rear door speakers) donnie5336 Audio and Electronics 11 06-23-2008 11:56 PM
'02 Envoy SLT Rear Air Suspension ? B2002mw Suspension 0 04-20-2007 12:52 AM
02 envoy rear a/c no top vent? junk OEM Issues 0 06-28-2006 12:02 AM
rear AC control question ruddy17 Interior 9 02-14-2006 01:44 PM
