Headlight Low Beam Problem! - Page 9 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Appearance > Exterior
Exterior Exterior repairs/modifications
Old 04-18-2014, 08:10 AM
rickhorner rickhorner is offline
2004 Chevy TrailBlazer LS
Silver Blue Metallic 4.2L I6 4X4
Low Beam Headlights no-go
Sorry you had the problem.... BUT I just had it this morning (17 April2014)
Thanks to all - I repeated your instructions and my HDM relay #46 is bad too... Headed to Chevy dealer - thanks again
Old 08-29-2014, 11:50 PM
DQ312 DQ312 is offline
Lurking Newbie
I have a 07 trailblazer and the low beams wouldn't turn on, I temporarily swapped the 45 and 46 module around and I had lights. Thanks TBLAZED
  #83
Old 12-01-2015, 12:56 PM
Rev Craig Rev Craig is offline
2004 Chevy TrailBlazer LS EXT
Left side low beam is inop
My 04 Trailblazer driver side low beam does not work. I replaced the bulb and no change. I checked the socket and found it was bad. I just replaced the socket and no change. The new socket has power at both leads but the bulb will not come on. I had another new bulb on hand so I tried that, no luck. Anyone else run in to this??? I checked the fuses and they are ok too. I am at a loss.
  #84
Old 12-05-2015, 06:12 PM
2004 Trailblazer Left side Low Beam inop part 2
I just replaced the entire headlight assembly thinking starting off with a clean harness and all. No change. Left side low beam still not working. Fuse is fine and has been checked with a tester.
  #85
Old 12-06-2015, 01:32 PM
Left Low Beam issue Fixed
Ok, I metered out the aftermarket light. bad ground. So I will be making a new ground wire.
  #86
Old 01-06-2017, 06:52 PM
DDS-029's Avatar
DDS-029 DDS-029 is offline
New Member
2003 GMC Envoy SLE
Black 4.2L I6 4X4
Me too! Haven't actually checked yet but from all of the questions about it, it has to be it.
Tags
headlights, low beams
