rear wiper doesn't work - Page 5 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Exterior
Exterior Exterior
Old 05-22-2010, 11:16 AM
playstrings playstrings is offline
2003 GMC Envoy SLT XL
Pewter Metallic 5.3L V8 4X4
Hey Dawg - was it the motor ??
Or is it still a problem ??
Old 05-22-2010, 11:46 AM
Interesting point in my testing ... I have no fluid pumping to the back ... I have 12 v on the orange....
Guess I will start with pulling the switch...
  #43
Old 05-23-2010, 10:41 AM
gmcman's Avatar
gmcman gmcman is offline
Senior Member
2002 GMC Envoy SLT
Onyx Black 4.2L I6 4X4
I have had this problem for a few years now. When I turn on the wiper...nothing, when I turn the switch all the way to the 3rd position, it works, sometimes the 2nd position.
When this happens, I turn the switch all the way on then off and it works.
Happens practically everytime I want to use it now, but moving the switch back and forth does the trick...in my case anyway.
  #44
Old 05-23-2010, 10:08 PM
Jerryod Jerryod is offline
2003 GMC Envoy SLT
Black 4.2L I6 4X4
Just a word from a very inexperienced envoy owner---remember every time you test to see if the parts you are replacing, have to be done with the tailgate properly CLOSED
My problem was in the harness at the top wher the hindges are--pulled out the grommet an the broken wire we found was the only thing wrong. Spliced and works fine.
  #45
Old 05-23-2010, 11:09 PM
gmcman's Avatar
Senior Member
2002 GMC Envoy SLT
Excellent tip....I also forgot that the wiper shuts off when the gate is open.
  #46
Old 07-12-2010, 11:57 AM
desert_dawg desert_dawg is offline
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
I have not been able to find the issue and have kind of given up on it for now. I can't see any breaks in the wiring harness between the door and the body. Without a wire schematic and expected voltage values, it will be difficult to troubleshoot.
  #47
Old 07-12-2010, 04:42 PM
Thumbs up
Many thanks to all the string ... tested at the motor connection - had juice - when I would turn the switch to different settings it would make noise at the motor ...
Ordered a used one on line - $45 worked great ... Thanks again to all.
  #48
Old 08-06-2010, 01:02 PM
mudturk37 mudturk37 is offline
2005 Chevy TrailBlazer LT
holy cow
i've spent a couple hours troubleshooting already and this never occurred to me
  #49
Old 08-22-2010, 09:31 PM
CSDenali CSDenali is offline
2006 GMC Envoy Denali
Dark Gray Metallic 5.3L V8 4X4
Mine has been in-op for a short time. I have experienced one dead battery that I cannot account for. Wiper moves about 1-3 inches than stops. I wanted to check the wire fray theory, but I cannot see any wires near my hinges. Where are they on the 2006?
  #50
Old 09-13-2010, 10:10 AM
Finally fixed my rear wiper
I took the motor apart again this weekend to see if I could just get around the pc card to wire the motor in to a dash switch of my own, just to get by.
In the process, I found a inductor coil on the pc card that one end came loose from the pc board. I resoldered the inductor back into the board and the motor works fine now.
Most likely shook loose with the repeated closing of the rear gate over the years.
Had I just replaced the motor, it would have fixed the issue for me, but I was fortunate to find the loose part and fix the motor's pc card instead.
