is the ticking noise under the hood the lifters - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Engine tuning and/or modifications
Old 11-24-2010, 08:24 AM
RedRocketZ28 RedRocketZ28 is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Originally Posted by Kenny24 View Post
yea, but coming from a jeep (late night drunk fun) to powerful suv (no more late night drunk fun) its a lot louder. i wish ihad a actual car garage...because i like to tinker and learn. by far what is the most power robbing emissions equipment on the car.
anybody made there own catch can? i was wondering about doing that rather than buy one.
If your truck is stock (judging by some of your other posts I would have to guess that it is) then a catch can is a waste of money and not worth it.
As far as emissions crap, just removing that isn't going to gain you anything. Add a set of long tube headers and a catback to let the motor breath and at that time delete your AIR system. That will be by far your best bang for the buck mods.
2004 TrailBlazer LT - 3.73's, G80, Bose, factory stock for now
2000 Camaro SS - Cam'd, Spray'd, still slow...
Old 11-25-2010, 03:43 AM
Kenny24's Avatar
Kenny24 Kenny24 is offline
2006 Chevy TrailBlazer SS (LS)
Black 6.0L LS2 V8 2WD
planning ahead is what i am doing
Car service: If it ain't broke, we'll break it.
  #13
Old 01-09-2011, 09:58 PM
Slow_Esuvee's Avatar
Slow_Esuvee Slow_Esuvee is offline
Summit White 6.0L LS2 V8 2WD
my tbss just started ticking really bad at idle . Im sure its a lifter ! Just ordered all new lifters ls7 and chromolly pushrods . 90k miles
06 TB SS white 2wd Vector tuned + good driver MOD
99 SS camaro vert # 405 bolton's 21k miles 13.21
89 TTA's #299 stock #1397 CAI K&N 8.43 1/8
  #14
Old 01-16-2011, 11:29 AM
Kenny24's Avatar
well the right side sounds a little louder than the left...so it could be something wrong.
  #15
Old 01-16-2011, 11:44 AM
bromanjr's Avatar
bromanjr bromanjr is offline
Senior Member
2004 GMC Envoy SLT XUV
Indigo Blue Metallic 5.3L V8 2WD
Also check for loose and or broken Exhaust Manifold bolts. There have been a lot of broken bolts out there, had (4) on the drivers side myself along with a stripped/cross-threaded nut on the flange connection. Caused lots of exhaust noises (sometimes sounds like a lifter)
I know the I6 was notorious for loose bolts and the V8s seem to be more broken bolts. I ended up getting most bolts out to replace with studs/nuts but had to replace the drivers side head because of broken bolts. This may only be true of the earlier V8s like mine not sure if yours would have this problem.
I have no longer have ticking noises since the exhaust repairs
182,000 and counting. Superchips 2914 Tune, NAV upgrade.
  #16
Old 01-17-2011, 12:57 AM
Jolly01's Avatar
Jolly01 Jolly01 is offline
2003 Chevy TrailBlazer LS
In my 20+ years of working with and on SBC engines the only time they stop ticking is when they stop running. Cast iron heads, Aluminium heads, roller cams, flat tappet cams, properly adjusted, improperly adjusted rocker arms, old springs, new springs, etc. I have even heard one bank a little louder than the other in healthy engines. Ifn the tick becomes extremelly lound under pressure, like climbing a hill or wide open throttle take offs, check your oil level and condition. Ifn both are ok then check the oil passages in the head.
  #17
Old 01-17-2011, 01:13 AM
nickluckie nickluckie is offline
Pewter Metallic 4.2L I6 2WD
its your fan cluth, mine was doing the same ticking noise and when it started ticking i unhooked the harness going into the fan shroud and it stopped, thats how i figured out it wasnt a lifter
  #18
Old 01-17-2011, 02:11 AM
ksoldani's Avatar
ksoldani ksoldani is offline
2003 Chevy TrailBlazer LTZ
I wouldn't jump to conclusions that quick..
Ticking from I6's just like everybody else said, is normal, it gets pretty bad when they're cold I've noticed in mine. Once they warm up it reduces quite a bit.
- Blue Township Fire/Rescue - KD0LDK - 911 Dispatcher -
'03 TB - 150k
  #19
Old 01-17-2011, 01:24 PM
Kenny24's Avatar
im pretty sure its not the fan, i have listened with my head about a inch away from the valve covers and i can tell a drastic difference. but as the other guy stated its normal im guessing to have one side louder. the only thing that kinda is a give away is when i got this car with 42k on it, the lifters were not loud, now is about to roll over to 50k and i can hear them from outside of the hood. i have warranty so if something goes wrong then thats there to cover it, it's just i hate knowing something is wrong if it is. after work i will see if i can catch some audio of it and you guys can tell me if im just paranoid or if something doesnt sound good after reading some post before this, i checked the exhaust and there all tight and snug. i'll also go in and see if the lifters are torqued right.
  #20
Old 02-19-2016, 10:47 AM
Gary_17368's Avatar
Gary_17368 Gary_17368 is offline
2007 Chevy TrailBlazer SS (3SS)
Silverstone Metallic 6.0L LS2 V8 AWD
Ticking Noise In Engine - '07 TBSS
Mine started ticking about 6-8 months ago (~48K miles) but it only does it after it has been driven and then shut off, and then restarted several minutes later. It definitely is a lifter; confirmed by my local mechanic who had the same issue with his Tahoe. Told me he switched from Mobil ! to another synthetic (Wolfshead or Pennzoil, I believe) and the problem stopped. Amsoil appears to be a good substitute for Mobil 1 and it will not screw up your warranty, if this is still an issue.
