Corsa Exhaust Dyno Numbers - Page 5 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > Exhaust Mods
Exhaust Mods Performance Exhaust Modifications
Old 11-30-2006, 11:19 PM
JCattSS's Avatar
JCattSS JCattSS is offline
2006 Chevy TrailBlazer SS
Summit White 6.0L LS2 V8 AWD
Originally Posted by 02redhawk View Post
Indeed. What I am concerned about are the people that really don't know any better...and they purchase this (or any) catback thinking they're going to get 18/30 out of it due to misleading(?) advertising.
Perhaps, but if thats what they really expect they deserve the results.
2006 AWD TBSS
12.59 @ 107 1.73 60
Old 12-01-2006, 10:40 AM
tbyrne tbyrne is offline
We have a shipment of the new Corsa exhausts arriving here in the next few days so there might be feedback posted on here by the end of next week.
  #43
Old 12-01-2006, 03:29 PM
BigD SS BigD SS is offline
Black 6.0L LS2 V8 AWD
Originally Posted by NobleForums View Post
You don't balance it with backpressure. Ask ANY reputable header or exhaust designer/manufacturer out there.
A good header (and to some degree exhaust) relieves backpressure and creates a vacuum. Smaller diameter tubes create the velocity necessary to scavenge at lower RPM's. Larger tubes facilitate scavenging at higher RPM's. Longer the tube lengths pull torque lower in the rpm band.
If backpressure helped (instead of velocity), you'd simply use crush-bent pipes instead of mandrel smaller diameter pipes.
http://www.ssheaders.com/header.htm
http://www.magnaflow.com/05news/magazine/05sportc.asp
http://www.burnsstainless.com/TechAr...ry/theory.html
http://www.uucmotorwerks.com/html_pr...torquemyth.htm
Read the magnaflow article and it talks about backpressure, and the need to have some.
Like I said, run your LS2 with no manifolds and exhaust and see what happens.
06 Trailblazer SS AWD, Vector tune, K&N CAI, Corsa Sport
99 Camaro SS, "some bolt-ons
99 Jeep Cherokee Limited
  #44
Old 12-03-2006, 11:36 PM
NobleForums NobleForums is offline
Where in the article are you reading that? The article doesn't mention that at all. It says to MINIMIZE backpressure and MAXIMIZE velocity.
And you're STILL not understanding scavinging, which is what a good header system and exhaust promotes. The power gains from exhaust scavinging have nothing to do with backpressure.
  #45
Old 12-06-2006, 09:40 AM
I fully understand exhaust gas scavinging and why you would want it. And yes, this article says to minimize backpressure and maximize velocity, but remember, it is a balancing act between the two. That's why different types of exhaust systems make differenct levels of power.
I think we are saying the same thing, however, describing it in a different manner/vocabulary.
  #46
Old 12-06-2006, 11:02 AM
Nukedog's Avatar
Nukedog Nukedog is offline
2006 Chevy TrailBlazer LS
Graphite Metallic 5.3L V8 2WD
No - it says to minimize and maximize it does not say to balance. Velocity and scavenging make the best TQ and HP numbers....
02 Busa 1397cc
05 ZX10R
08 Tundra DCRB 5.7
  #47
Old 12-06-2006, 03:18 PM
To me, minimize one variable and maximize another is a "balancing act".
  #48
Old 12-07-2006, 03:32 PM
Pyrobob Pyrobob is offline
Scavenging is based on your backpressure. Varying backpressure effects the location of the stationary shockwaves that form inside each exhaust tube. On log style manifolds, these waves are just left to collide. On headers, the waves stretch to varying distances, depending on the exhaust pulses. As one speed of air (pulse) hits the other speed of air (backpressure) it creates a Mach wave. A second wave can speed it back up. It's similiar to a Venturi.
The shockwaves, created by backpressure, in turn create the vacuum that causes scavenging. Low backpressure allows air to move through the cylinder faster, giving you great high RPM horsepower. With the right tuning, a naturally aspirated engine can actually pull more than atmospheric pressure due to enough vacuum. Torque, however, is created by slower moving air, and a relatively higher backpressure.
Open headers and straight pipes can't be beat at the track (and are fairly handy in boosted conditions). For trucks like ours, I would maintain enough to keep my torque band in the 3500-4500 range. But, that's just my IMO. And I am NOT an expert at exhausts or engines.
Corsa Exhaust - TrailBlazer Exhaust tip Assembly 14035 tjloeb Exterior 2 07-05-2008 10:32 AM
Corsa Sport exhaust TBSS07_Chappy Exhaust Mods 2 03-07-2007 10:16 AM
