[SOLVED] How I fixed Sunroof & Overhead water leaks (NOT a plugged drain tube). - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Exterior
Exterior Exterior
Old 12-08-2009, 04:46 PM
EnvoySLE02's Avatar
EnvoySLE02 EnvoySLE02 is offline
2002 GMC Envoy SLE
Black 4.2L I6 4X4
I had started this in another thread ~1 month ago, which had grew in size since then. I wanted this thread to have the correct title, and have the problem and solution in the first message.
The water leak I had would happen even in a light rain, and with the truck parked. Before I even moved the truck, I would notice a wet spot on the headliner above my (driver) head, about a half an inch round. Sometimes, after I back the truck up or turn out of the parking spot I am in, a few drips would come from the Overhead grill openings. Just a few drops, and then nothing (still, very embarrassing when you have company). I tried the drain tubes, and they seemed fine (lot's of threads here on drain tubes, so I will spare you the diagnostic details).
So one time, shortly after the rain stopped, I went out and looked inside the sunroof (before moving the truck) and here is what I found. I will leave you with the three pictures below, since one picture is worth a thousand words (especially when the picture has words on it ).
I hope this helps someone else fix their leaky sunroof / Overhead.
Click image for larger version
Name:	Water leak_1.jpg‎
ID:	8438   Click image for larger version
Name:	Water leak_2.jpg‎
ID:	8439   Click image for larger version
Name:	Water leak_3.jpg‎
"To be brave, you must first be afraid. For true courage lies in overcoming fear, not in its absence" ... Blue Power Ranger.
Old 12-08-2009, 05:23 PM
lynch55's Avatar
lynch55 lynch55 is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 4X4
[SIZE="4"]This should be a sticky![SIZE="2"] Very good job of showing pics with explanation![/SIZE][/SIZE]
Old 12-08-2009, 05:47 PM
SilverUnicorn's Avatar
SilverUnicorn SilverUnicorn is offline
2006 Chevy TrailBlazer LS
Very well diagnosed and presented! Great work!
[CENTER]
[/CENTER]
Old 12-08-2009, 07:22 PM
EnvoySLE02's Avatar
2002 GMC Envoy SLE
Black 4.2L I6 4X4
Thank you guys.
Old 12-08-2009, 10:27 PM
kaptaink kaptaink is offline
2003 GMC Envoy SLT XL
Pewter Metallic 4.2L I6 4X4
well it is crazy you posted this on the same day I figured the exact same thing out!!!
I had pulled the headliner down just a tad on the drivers side and found the same evidence, but mine was not leaking as bad
great pics and post - we are having a pretty hard rain here in KY tonight/tomorrow so the "voy" sits in the garage drying out - will repair tomorrow STICKY THIS!!!
PS - I can get some other pics of the wire harness inside the headliner while the drivers side is still pulled apart let me know if it is worth posting some pics
thanks again for posting this
Old 12-09-2009, 02:18 AM
Black04 SLT's Avatar
Black04 SLT Black04 SLT is offline
2006 GMC Yukon Denali
Black 6.0L LS2 V8 AWD
Great write up-love all the diagrams/lines/explanations---well done
04' Voy[B] SOLD[/B]
Loaded 06' Black GMC Yukon Denali
Old 12-09-2009, 09:20 AM
EnvoySLE02's Avatar
2002 GMC Envoy SLE
Black 4.2L I6 4X4
Originally Posted by kaptaink View Post
I had pulled the headliner down just a tad on the driverís side and found the same evidence, but mine was not leaking as bad.
It's a good thing you caught the leak before it turned into the mess that mine was.
Great pics and post - we are having a pretty hard rain here in KY tonight/tomorrow so the "voy" sits in the garage drying out - will repair tomorrow STICKY THIS!!!
I do not have a garage, so the truck had Green masking tape around the sunroof and the windshield for two days until I made sure the silicone dried up well. So far I fixed three water leaks: Roof rail, rear right corner; windshield, upper left corner; and the sunroof tracks. My truck should be the poster child (or truck ) for water management. I didn't mind the tape. The least I could do for GM after all the trouble I went through to fix the water issues is drive around publicizing the fact their product leaked from pretty much everywhere
PS - I can get some other pics of the wire harness inside the headliner while the driverís side is still pulled apart let me know if it is worth posting some pics.
Sure, the more pictures the merrier. I should have taken one myself while my headliner was down. I don't know why I did not.
Old 02-07-2010, 06:01 AM
JOETENO2's Avatar
JOETENO2 JOETENO2 is offline
Pewter Metallic 5.3L V8 2WD
Mine did the leaky thing five days ago. May try this fix today before the game.
Old 02-09-2010, 08:26 PM
EnvoySLE02's Avatar
2002 GMC Envoy SLE
Black 4.2L I6 4X4
Hopefully this fixes your truck too. Mine is still leak-free since I fixed it in December.
Old 02-14-2010, 07:25 PM
doug42 doug42 is offline
2002 GMC Envoy SLT
Thumbs up Leaking Roof 02 Envoy
Thanks for that info as it is exactly what happened to my 02 Envoy. The water is finding its way into the overhead control panel and dripping onto the rear view mirror. Thanks to your pictures I could trace the dampness back to the source and now have to get some of that good black silicone sealer.
Living out here here on The Wet Coast, a sealed auto is essential!!
