lift kit - Page 7 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 General Tech Q&A > Off-Road
Off-Road For suspension, wheel, and tire questions DIRECTLY related to Off-Roading.
Old 08-18-2016, 09:53 PM
Paddy-_- Paddy-_- is offline
Just bought a stock 04 ls and I am looking to lift it. I just want to lift as much as I can without problems. Also would like to know biggest tire size to get. Please point me in the right direction
Old 10-24-2016, 08:44 AM
Sporadic01 Sporadic01 is offline
here for more lifted tb's
  #63
Old 01-07-2017, 12:15 PM
skippyd skippyd is offline
is it really worth lifting you envoy 2 in for 2 in taller tires?
  #64
Old 05-09-2017, 05:08 PM
Eliteshooter76 Eliteshooter76 is offline
2008 Chevy TrailBlazer LS EXT
Blue 5.3L V8 4X4
Hello new to forum
Looking to lift my 08 Trailblazer 4wd . Want to fit atleast 33's or maybe 35's any insight would be appreciated
  #65
Old 01-17-2018, 12:20 AM
fastflyin50 fastflyin50 is offline
255/75r17's fit with flying colors
i did 2.25 inch front lift and 1.75 inch rear lift with 1.25 inch wheel spacers, all pretty affordable stuff on ebay or other sites you are going to want to make sure you have a spring compressor to get front struts in easier i dont do any hard wheeling with this little truck but it is damn good in deep snow and for hunting the tires i put on were a 255/75 r 17 only thing that wanted to rub was inner fender on the front of the wheel well but after a few minutes of looking at it there was spacers holding inner fender back...removed it and put new plastic push pins in now looks like i can go a full inch taller tire and maybe 3/4 inch wider without ever having a problem its looking hard to find a 33.5 that narrow the stock rear shocks worked just fine while my wife drove it but i find they top out really hard the minute you hop off the pavement im doing some research now to find some longer ones and about 15,000 miles away from putting alot more rubber under it im thinking a 285/70 r 17 should fit just fine with minimal trimming of the front air damn
  #66
Old 01-17-2018, 04:40 AM
markmc's Avatar
markmc markmc is offline
Supporting Vendor
2007 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 2WD
you should also note that any lift spacer that installs outside of the strut assembly will cause over travel and damage the front disconnect and ball joints.
those style lift spacers are mostly sold on ebay.
1.25" wheel spacers are fine but you need to grind the factory lug studs for the wheel to mount flush to the hub.
you get what you pay for....
  #67
Old 01-27-2019, 09:28 PM
Dustin28906's Avatar
Dustin28906 Dustin28906 is offline
Lifted tb
Hey what was done to your tb. Is that just a 2 inch body lift
