BB - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > General TrailVoy Discussion > The "How-To" and DIY Section
The "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 10-09-2018, 02:07 PM
Intlhud Intlhud is offline
BB
What is the best procedure for cleaning the throttle body. I am in the process of trying to do the cheap stuff first, in search for a misfire problem on cylinder 5.
Old 10-09-2018, 02:12 PM
rtliquid rtliquid is offline
Dark Gray Metallic 4.2L I6 AWD
If you have a misfire on Cylinder 5, you should be looking at Cylinder 5 - not the throttle body. Swap the #5 coil with #4 and see if the misfire follows. If so, it's a bad coil. If not, swap the plug and see if the misfire follows.
Old 10-09-2018, 02:18 PM
BB
Already tried swapping coil pack with #2 and inspected wires to that component. Diagnostic still shows misfire in #5. This was not a problem before. Just started a couple weeks ago. I am going through cleaning, changing filters for general maintenance, and read somewhere that cleaning throttle body might solve some issues.
Old 10-09-2018, 02:26 PM
BB
I picked up this Envoy at a junk yard about a year and a half ago. Donít know any history, other than damage was all on the right front. 160k miles. Replaced some suspension components, bought new tires, fixed AC, and parked it for about a year. I am suspecting that the gasoline in the tank might be my culprit, as it is now just over a year old. Maybe clogged injector? I drained remaining fuel and filled up with new gas, but the ďdamageĒ may already have been done. What is the procedure for cleaning injectors?
Old 10-09-2018, 02:35 PM
OK. Have you replaced or swapped the plugs as well? AC Delco iridium 41-103. There is a very detailed throttle body cleaning procedure on this site - a search should reveal it for you.
Old 10-10-2018, 09:14 AM
BB
Plugs are on my list of things to change. Injector cleaning is a priority, as well, because I suspect old/contaminated fuel. I am sure there is a descriptive procedure somewhere on this website for that. If I go through all of that with no success, compression check is next. From there, I donít know. Along the way, Iím checking filters, throttle body, etc., just to take care of general maintenance.
Old 10-10-2018, 11:52 AM
Since the code is specific to the #5 cylinder, my recommendation would be go after the plugs first. Cheapest, easiest, and most likely culprit. The throttle body can't target a specific cylinder, although a good cleaning is definitely in order anyway.
Old 10-17-2018, 08:17 PM
Thetonymartin's Avatar
Thetonymartin Thetonymartin is offline
I second this motion.
Old 10-17-2018, 08:33 PM
Linusridesred's Avatar
Linusridesred Linusridesred is offline
#5 is the most problematic for all TBs and Envoys. Water drips down in there and fouls out the plug and coil. Did you clear the codes after swapping coils?
Old 10-18-2018, 12:52 PM
Bob
Thanks for all the input. Since my last post, I changed to new, recommended plugs and replaced the air filter while I was there. Thereís a noticeable improvement, and Iím guessing the plugs have most to do with that. The old ones looked rather used up. However the number 5 plug looked no different from the others, clean with no oil or unburned fuel though worn like the others. I doubt the plugs have ever been changed, so it was money and time well spent. I am still getting misfire codes, but no longer specific to cylinder 5. It varies to a different cylinder every time I check it. Yes, Iím clearing the codes at the end of each diagnostic, and the Service Engine light goes out for a while. It sometimes stays extinguished for as much as ten minutes, and sometimes it comes on the instant I put the vehicle into reverse. I can feel what I suspect is the misfire nearly all the time I am driving, but itís barely noticeable unless I put it under a load. The plugs improved on that, but Iím still chasing a gremlin. Any suggestions will be considered. Thanks.
