Brights turn on with right turn blinker - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-11-2018, 08:55 AM
Unclechawie Unclechawie is offline
Been having this issue for a while. When I turn on the right blinker to change lanes or make a turn, it turns my brights on 60-70 percent of the time. I judged starting having issues turning the brights off as well.
Any thoughts on this on this would be appreciated.
Old 10-11-2018, 11:49 AM
If it's intermittent like you say, I would say the stalk assembly on the steering column is bad.
Old 10-13-2018, 05:39 PM
Marshall_gibbs Marshall_gibbs is offline
My trailblazer was doing the exact same thing, it's the turn signal switch on the steering column, i replaced mine and haven't had any issues since. It's a common trailblazer problem.
Old 10-17-2018, 07:09 PM
nicholasallison's Avatar
nicholasallison nicholasallison is offline
It seems to be a common issue. Happened to me a year ago. Some advise, I searched the part number for the turn signal stalk on walmart.com and found it available from one of their online sellers for like $34, auto places wanted over $100 for it. You'll also need a steering wheel puller to swap it, but it is pretty easy, and problem solved.
