Whine through speakers when you accelerate - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > Announcements & Feedback > Latest GM News
Latest GM News A section for industry news, recalls & technical service bulletins.
Old 03-12-2018, 09:37 AM
Lemonpledge Lemonpledge is offline
Silverstone Metallic 4.2L I6 2WD
I have an 07 trailblazer and sometimes when the radio is on the speakers i hear a whine. When i step on gas it is heard through the speakers. I replaced the head unit of the radio with an aftermarket stereo and still get the whine. But now it is not as load. Is this noise coming from the alternator? And if it is does the alternator need to be grounded? Thanks.
Old 03-12-2018, 05:26 PM
gstrekkie gstrekkie is offline
Whine thru speakers
Hi I have run into this a few years ago with my trailblazer. If you have the stereo controls in the back seat area that may be your culprit. I have an lt with the bose system I found some links here that helped. In a nutshell use some dialectric grease on the connector located inside the center console that connects the rear entertainment controls. changing the head unit might not have an effect especially if you are still using the same wiring harness and the stock amplifier. I havent heard the noise for a few years since I did that. Good Luck hope this helped!
Old 03-12-2018, 05:37 PM
I don’t have a backseat control center nor swc. I am at a loss. At least it isn’t as loud as it was. But still annoying.
Old 05-18-2018, 06:41 AM
rentalcarsuae2 rentalcarsuae2 is offline
BMW Buick BMW
Fire Red 6.0L LS2 V8 2WD
Nice Post.
Old 06-02-2018, 12:48 AM
mbelcher mbelcher is offline
chevy colorado Chevy Other
4.2L I6 2WD
cd
nice fix gotta try this
Old 06-05-2018, 12:59 AM
wags69 wags69 is offline
2007 SAAB 9-7x
Lingonberry Red Metallic 4.2L I6 AWD
It's usually a bad connection on one of the radio components.
Also, try using a ferrite choke to supress the noise
Old 07-02-2018, 12:08 AM
Alainzen Alainzen is offline
2007 GMC Envoy SLT
Bad ground
I had a similar issue and the aftermarket audio system made it worse. I was able to isolate the issue(s) on the third attempt to the main audio connector, mostly a ground problem.
A lot of zip ties to secure the cable where they are happy to be, no whining! And some patience...
Old 08-04-2018, 09:20 AM
miketexas miketexas is offline
Sometimes I would hear a whine in my speakers but turning up the volume would drown out my wife.
Old 08-06-2018, 08:24 AM
adamjeeps adamjeeps is offline
2006 GMC Envoy SLT
Light Pewter Metallic 4.2L I6 4X4
I did this and for good measure, dielectric greased up the main purple connector underneath in the middle of the console while I had it all torn apart looking for possible reasons for this issue. Also wrapped some electrical tape over the metal bracket down there where it is fastened. Seems some fixed it by just unplugging and replugging in the harnesses.
I realize this does not help you but try some dielectric grease on your head unit harnesses.
Old 02-05-2019, 01:22 PM
setauketjeff's Avatar
setauketjeff setauketjeff is offline
Silverstone Metallic 4.2L I6 4X4
Is this hum also present when playing a CD? Lets first determine that it is from within the system. Also check if you can hear it when using headphones through the rear unit's jacks.
