‘04 trailblazer 4.2l non ext - power steering mystery - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-14-2018, 11:00 AM
Pquada Pquada is offline
Midnight Blue Metallic 4.2L I6 AWD
Hey all- had a nice leak in the power steering lines just below the brake booster area. Cut the bad parts out and fixed the leak. Almost immediately the pump died. Swapped new pump, flushed system, bleed properly and the new pump failed in two minutes. Flushed system again, replaced pump same brand same thing happened. Trying different brand now...
What y’all think?? Two bad pumps?
Old 09-14-2018, 03:32 PM
What brand? You can never go wrong with AC Delco OEM or AC Delco Professional lines. The AC Delco Advantage line is to compete with the local aftermarket parts houses.
Old 09-25-2018, 10:47 PM
Spanker Spanker is offline
2009 Chevy TrailBlazer LT
Graystone Metallic 4.2L I6 4X4
Did you mix the two lines up ?
Cross the high and low pressure lines ??
I need confirmation from the forum, as my truck is out of state:
...but I believe the high pressure goes to the more lower fitting on the steering rack.
