17volts?omg - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > General TrailVoy Discussion > Audio and Electronics
Audio and Electronics Discuss car audio, video, navigation, alarms, and other electronics here.
Old 09-13-2018, 10:39 PM
JMTGMC426's Avatar
JMTGMC426 JMTGMC426 is offline
17volts?omg
Any external type voltage regularor on my Envoy before I go to get a new alternator ?
Old 09-14-2018, 08:10 AM
Akrich Akrich is offline
2005 Chevy TrailBlazer LT EXT
My understanding is the voltage regulator is built into the alternator.
Old 09-14-2018, 08:28 AM
NJTB04 NJTB04 is offline
Pewter Metallic 4.2L I6 4X4
And the PCM controls the voltage.
Old 09-14-2018, 09:28 AM
TB-Al TB-Al is offline
How do you know you have 17 volts? I'm thinking a simple issue with the voltage meter stepper motor. Much more likely than a failure of the PCM/ECM computer which is the voltage regulator for the alternator.
Old 09-14-2018, 09:36 AM
miketexas miketexas is offline
As always before you start throwing parts at it, read the voltage at the battery with a volt meter with the engine running. Should be around 14 volts. My gauge in the vehicle reads about 20 volts because the stepper motor in the instrument panel is bad.
Old 09-19-2018, 09:30 PM
JMTGMC426's Avatar
17volts?omg
I know it was producing 17 volts because I tested the system. I used my trusted multimeter .
Old 09-21-2018, 11:21 AM
Then you have a very expensive problem because the voltage is computer controlled. Time to take to dealer unless you have a tech II because the new computer will have to be matched to the VIN.
Old 10-08-2018, 03:25 AM
JMTGMC426's Avatar
Update on the ⚡️High voltage⚡️
It’s higher we runnin 18V now ,y’all still runnin 12-14 that **** is week.
Old 10-08-2018, 08:23 AM
rtliquid rtliquid is offline
Dark Gray Metallic 4.2L I6 AWD
Are you glowing?
Old 10-09-2018, 10:59 AM
JMTGMC426's Avatar
Jk it sucks I drive it daily though. It’s tripping me out , just waiting to see what’s next.
