2008 trailblazer A/C blowing hot air - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-08 SS General Tech Q&A > General
Old 04-28-2019, 11:23 AM
Crobbi Crobbi is offline
The a/c system only blows air thru defoster and feet area no matter what. Wont blow out dash area even if i have it as heater. Pulled fuses 36 and 39. Still blows hot air most of the time. Every once in a while i will get cool cold air but never thru dash. Suggestions? Yes i have a new battery.
Old 04-28-2019, 01:58 PM
Sounds like you may have two problems. One being that apparently nothing comes out of the face vents, this most likely is the Mode actuator.
Next, you need to determine if the AC system is actually working. With engine running and HVAC controls set to AC, see if the AC compressor is engaging and the silver cylinder on the passenger side firewall is getting cold. If these don't, then the system needs to be troubleshot.
Old 05-01-2019, 07:08 PM
RPatton76 RPatton76 is offline
If yours is like mine, the A/C compressor is not allowed to engage when the coolant temperature gauge has an error message of "low coolant temperature" and a check gauges light is also lit up. We clear codes for our gauge to work again. Not sure why it works for us, but we have similar mode issues with only face vents that work or defrost, no floor vents, ever.
Rob in AZ
Old 05-02-2019, 01:11 PM
John in RI's Avatar
John in RI John in RI is offline
2005 BowTie TrailBlazer LT
Olympic White '50U' 4.2L I6 4X4
Read thru this thread,.... should be all the info you need to get the HVAC mode actuators replaced.
https://forums.trailvoy.com/showthre...69#post1594969
I've posted a few pics to that thread to help ID each of the accutators and to show how they must be indexed before they get installed.
https://forums.trailvoy.com/showpost...9&postcount=36
P.S. I've got good spare actuators available for sale. If you are interested,just send me a PM for more info.
2008 Trailblazer Air Conditioner blows hot air stever0114 General 9 08-30-2018 03:33 PM
2008 trailblazer LS,Problems with temp gauge and A/C ceast71112 General 3 08-29-2017 07:32 PM
Cold Air Inductions In. new supporting Vendor!! Bill at CAI Inc Basic Vendor GroupBuys 25 10-25-2011 05:39 PM
A/C blew hot air saadmoughal OEM Issues 0 06-27-2011 02:50 PM
