Shift solenoids or 3/4 clutch - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Transmission Mods
Transmission Mods Performance Transmission Modifications
Old 05-11-2019, 02:24 AM
Smudger Smudger is offline
I have been using this forum for a while with great success so thanks to all but now I have a question.
My 2005 Trailblazer ext with 158k miles has a transmission problem. Reverse is good and it takes off as usual through 1st and 2nd then when it should go into 3rd it just revs, if I let it get to around 4K and back off the throttle it goes into 3rd but never into 4th. Would it be the shift solenoids (which I could probably change myself) or bad 3/4 clutch (which I would take into a shop to be rebuilt). If it needs to be rebuilt how long can I continue to drive it while I get the money together to get it rebuilt (I am currently only using it around town where I don’t need to go into 4th - I have probably done 300 miles like this already and what will be the next sign(if any) that total transmission breakdown is imminent?
Old 05-21-2019, 03:48 PM
kcducttaper kcducttaper is offline
4.2L I6 4X4
I'd check the fluid level and pull the tranny codes first. A lot of auto parts places will scan it for free. That should at least get you pointed in the right direction.
A/C Clutch Bearing - How to...... Zubius OEM Issues 101 06-05-2019 06:23 PM
4.2 Fan Clutch Replacement with Pictures Bowhunt_Pro OEM Issues 56 09-24-2018 04:50 PM
Bad water pump, fan clutch, or both :/ northfacetb123 OEM Issues 9 08-15-2011 03:17 PM
fan clutch? stingray OEM Issues 15 03-01-2009 11:20 AM
Truck wont shift at 3/4 to full throttle past 5g randyusarmy 4x4 Drivetrain 5 10-07-2008 12:28 AM
