03 Envoy 4.2 Signfantly loses power uphill - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > General TrailVoy Discussion > The "How-To" and DIY Section
The "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 07-24-2019, 08:22 PM
Monte27 Monte27 is offline
2003 GMC Envoy SLE
Fire Red 4.2L I6 4X4
Originally Posted by PalmBay04TB View Post
My 04Tb with 220k miles had same probs, it was a plugged up cat convertor, was just clear enough to run but was running real hot and weak....put on new cat and its like a new truck again.
That symptoms sounds just like mine. Only got 160k on it, so I'm still hopin its not the cat. Thanks, and have a great day
Old 07-24-2019, 08:28 PM
2003 GMC Envoy SLE
Originally Posted by RPatton76 View Post
It is not likely an evap issue should affect power, especially if you're revving it much. When my other car cats died, the first one broke into small pieces and plugged up the 2nd cat and made power and mileage suffer and, though I didn't notice it, it was getting a quieter exhaust at the time. After changing cats, the exhaust sound came back to normal. Mileage was also going down at the time. If your problem is really that the motor gets too hot, I'd put in a new thermostat and maybe go down to the next lower temperature, and be sure to burp out any air that may cause overheating.
Rob in AZ
Thanx Rob, Just waitin for the thermostat. Parts store had to bring it in. Getting it in an hour, and praying its the cause. Have a good evening. Aloha from Hawai'i
Old 07-24-2019, 10:09 PM
keenxxx keenxxx is offline
2005 Buick Rainier
Black 5.3L V8 AWD
Power loss - you will need to verify fuel trim & O2 sensor readings during power loss on a scan tool. A clogged catalytic converter could cause power loss. Check w/ a back pressure gauge usually into the O2 hole. I work in a shop and realize DIY guys donít have all the proper tools but blindly hanging parts is a waste of time and $.
Old 07-25-2019, 06:40 AM
junkyardog junkyardog is offline
Graystone Metallic 4.2L I6 4X4
Power loss
Definitely is the CAT. I had this exact same issue 2 years ago... I will pulling a small trailer and about an hour into my trip, going up a hill, I lost all kinds of power; had to go into the shoulder because I couldn't go past 30 MPH. After it cooled down a bit, it was OK, but came back again once I started driving. Went to my tranny place thinking it was the trans and shop said replaced the CAT and all good.. It's been good since... Mike
Old 07-25-2019, 07:52 AM
Jkb242 Jkb242 is offline
2006 GMC Envoy Denali
pewter 5.3L V8 2WD
Sounds like you have some very solid advice not surprising however. Regarding the over heating, unless there is excessive back pressure from what sounds like an agreement on the CAT, the over heating could be a separate issue. Hopefully you have never mixed Dexcol with the green stuff regular antifreeze. The reaction between the two is the production of harden deposits throughout the system. Otherwise, I think the thermostat is a good suggestion. Make sure the engine side of the radiator find not crushed from previous work like from a water pump replacement. If you keep it long enough you will have to change it however, DO NOT USE ANYTHING BUT ORIGINAL AC DELCO! Otherwise, youíll likely be doing the replacement AGAIN within a year!
Best of luck!!
[B]Advertising exploits inverse logic where marketing wank highlights deficiencies rather than strengths.[/B]
  #16
Old 07-25-2019, 08:23 AM
zoysia zoysia is offline
I had same “no power on hills” with my ‘02. It was due to a partially blocked muffler. My son had been rear-ended on a snowy road and exhaust pipe shove creased muffler.
  #17
Old 07-25-2019, 10:57 AM
2003 GMC Envoy SLE
Thanks Guys. Parts store didn't get me the thermostat yesterday, so I'll have to wait till this afternoon for that. But I guess majority feels its the cat, and I guess that explains the low Boggin sound in engine when theres no power. Sounds like a 4 barrel that is badly adjusted and just dieng for fuel. I will let you folks know the outcome. Thanks again to all. Have a great day
  #18
Old 07-25-2019, 01:45 PM
RPatton76 RPatton76 is offline
When I was breaking in a cam on a V-6 S-10, I swapped 2 spark plug wires but drove it that way for a half hour and then saw the glowing red hot catalytic converter. Boy did it have some major power, after hollowing that out! So, if you drive it long and fast enough in the dark, you can see if a cat is glowing if you can stop fast enough and get out and look. If it is getting *that* hot....
Rob in AZ
  #19
Old 07-27-2019, 05:16 PM
2003 GMC Envoy SLE
Well guys, heres where I'm at...Bypassed the cat... same problem. Someone told me the rubbish from the cat could have been plugging the muffller so I removed muffler and still ran the same. When parked I gradually take rpms up to 3k with no miss at any level, and it revs without bogging. On the road...slow acceleration, crawls on the up hill and motor sounds like its a 4 barrel with a big time boggin issue.
