2004 4.2 Envoy Random misfire and no power - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 11-30-2018, 08:37 PM
ydrogsavid ydrogsavid is offline
I have a 2004 envoy with the 4.2 I replaced the plugs and coil packs 6 months ago and it has run perfect. I went to start it up las week and it ran like crap. I put my code reader on it and got codes for the cam position sensor and the vvt actuator solenoid. I replaced both. Now I onlt get the p0300 code and it runs horrible. Any ideas? Anyone? This has been a great vehicle and I can't afford to replace it.
Old 12-01-2018, 07:04 AM
45Frank 45Frank is offline
2003 GMC Envoy SLT XL
Carbon Metallic 4.2L I6 4X4
My post is right below yours and these are the codes my headache started with. Good luck I'm still trying to figure it out although mine has been a little better running and haven't read the codes this week yet!
Old 12-01-2018, 12:06 PM
sounds familiar.
Sounds like your issues are similar to mine, however mine is not drivable, A buddy told me valves, valve seals and possibly a head replacement. I will check back at the end of the day to see if we came across anything less intimidating.
Old 12-01-2018, 01:31 PM
Oh well this is getting old really really fast.
It runs and idles even better today BUT!!!!!! I was idling at a light for 2-3 minutes and it acts as though it going to stall. This is a first. Always something new!!!!
Old 12-01-2018, 02:42 PM
Glad you are getting around.
Sounds like you are making progress
Old 12-05-2018, 07:39 PM
JAL2 JAL2 is offline
2004 GMC Envoy SLE XL
When you replaced the plugs and coil packs, did you also change the boots, as these usually go bad before the coil pack?
I suggest you use a scan tool, or an ODBII app such as Torque, to determine which cylinders are misfiring and try swapping coil packs between good and bad cylinders to see if the problem stays with the cylinder or follows the pack.
Old 12-05-2018, 08:22 PM
I did replace the boots as well
My problem is getting narrowed down to a fuel issue, (I think.) I replace the fuel pressure regulator a few years ago o I had not even considered it, I just came back in from garage and the vac line off of the top of it has no change to engine while connected or disconnected. Anyone know if I am on the right track? I have been using a code scout from the beginning. I only get 2 codes now p0300 and p0300pd. I have yet to find out what the pd is.
Old 12-06-2018, 06:18 AM
sclutzo sclutzo is offline
2004 Chevy TrailBlazer LS EXT
Exclamation
I had exact same problem with my 2004 4.2L...rough idle no power. Changed plugs. And got the actuator and cam shaft sensor code.. checked the fuel pressure,replaced fuel filter... and it turned out to be the stupid O2 sensor! Swapped that out and it has been running good since August. Never did get a code for the sensor either. Pretty sure it was bank 1 sensor 1. First one on exhaust manifold. Canít remember if I had to reset the ECM or not for it to relearn the adjustments though.(old age
God luck. I hope that works for you too!!!
Old 12-06-2018, 07:14 AM
Thank you
I am going to pull the upflow sensor to test. Thanks for the tip!
Old 12-14-2018, 07:07 PM
Update.
I ended up doing a compression test and there is 0 on number 5. I am going to pull the valve cover off and hope for the best. Good news is, compression is good on the rest.
Tags
4.2, camshaft sensor, camshaft solenoid, help help help please, misfire
