Going from P-metric to LT - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Tires
Tires Tires
Old 08-09-2017, 11:20 PM
sandness sandness is offline
2006 GMC Envoy Denali
Carbon Black Metallic 5.3L V8 4X4
I do a lot of reading on here to help me with various issues with my 06 Envoy Denali. The wife normally drives this vehicle and she told me she wanted some beefy tires on it. Well, enough said. I've ordered a 2" lift and some 1.5" hub/wheel-centric wheel spacers as there wasn't squat available in AT tires for the stock 18" wheels. I've decided to go with a 265/65r18 tire as they are a common size and seem like they should fit based on my measurements (unfortunately there aren't many Trailblazers/Envoys with stock 18" wheels for me to compare to.) I was pretty much set on ordering a set of Falken Wild Peak AT3W's based on the meaty tread design and decent feedback I've read on that line of tires. They are about 46lbs in a P-metric size with 13/32" tread depth. That's about 8lbs heavier than the highway tires it is wearing currently. But, to throw a monkey wrench into my plans I just today came across a deal on some Nitto Exo Grapplers in LT265/65r18. They look a bit beefier to me, have 18.3/32" tread and are a tougher 10ply tire. However, they spec out at a staggering 58lbs. This has me worried about wear and tear as its about 20lbs heavier than the tires it has now. Do you guys that run 32" or more LT's run into problems with the extra weight? This is my first time running bigger tires on 4x4 and my brain says don't worry about it, its a body-on-frame V-8, all sorts of pickups/suvs run big tires. But my gut makes me think it could be a mistake.
Old 08-10-2017, 03:08 PM
Looks like I've ruled out the Exo Grapplers after doing more research. Although they have the 3 peak snowflake rating, they appear to only have shallow sipes. I spoke to Discount Tire and they confirmed that the sipes are only 6/32" deep and the snow rating is due to the fact that they are studdable. Looks like the Wild Peaks will be my choice.
Old 08-11-2017, 02:19 AM
Ashlanders8's Avatar
Ashlanders8 Ashlanders8 is offline
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
Check out hankook dynapro atm got them on mine I can go anywhere in anything I do have 16's though?
Old 08-11-2017, 11:14 AM
There are quite a few trucks at work running the Dynapros and I like them better in person vs pictures I've seen. I am running some Hankooks on my Impala that perform well but haven't been on long enough to gauge wear. My father manages a tire warehouse so I can buy/order most tires and my price on the Falkens is about $630 and cheaper than the ATM's.
Old 08-11-2017, 11:36 AM
The dynapros on my TB are new but the ones on my f150 are about 3 years old and only about 50% gone you rotate them they will last
Old 01-22-2018, 11:42 PM
monteman's Avatar
monteman monteman is offline
2004 Chevy TrailBlazer LT
Black 4.2L I6 4X4
And the winner is?
Just wondering what you finally went with? Prices? Can we see pics?
Old 01-23-2018, 12:49 AM
I had created a new post when I got my new tires.
https://forums.trailvoy.com/showthrea.../topics/195121
They are Falken Wildpeak AT3W's in 265/65R18, p-metric. You can see that thread for more details. Thanks.
Click image for larger version
