Temperature Mirror Problem Solved! - Page 3 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Exterior
Exterior Exterior
Old 05-26-2007, 04:50 PM
SilverUnicorn's Avatar
SilverUnicorn SilverUnicorn is offline
2006 Chevy TrailBlazer LS
OK, I finally got all the parts I need and I am going out NOW to get this working! Thanks for all the part #'s!!!!
I got the connecters from Mouser, and I will have extras when I am done (I hope) if anyone needs them!
Wish me luck! Will post pics when done!.
Old 05-26-2007, 07:06 PM
Holy Crap!!! It works!!!
So a $100 way for me to tell the temp
Looks nice though. Pics to come
  #23
Old 05-26-2007, 09:53 PM
mtt's Avatar
mtt mtt is offline
2005 Chevy TrailBlazer LS
Medium Red Metallic 4.2L I6 2WD
Good Job Chris! It seems like once you have a vehicle with it, its hard to do without it. My Silverado has the temperature mirror, and when we bought the TB without it, I knew that eventually it would have to be upgraded. There's only one thing I would still like to know. In my part of NC, I have seen extremes down to 12 degrees and up to 107 degrees. I would like to see what 9 degrees looks like, is it 9 or 09? I'm sure somebody here already knows, especially the Canadian members! Congratulations again!
Mike
  #24
Old 05-27-2007, 08:23 AM
Mike
Thanks Mike! Couldn't have done it without you!!!!
Thanks everyone here at Trailvoy for the continued knowledge and support!
  #25
Old 07-01-2007, 06:21 PM
richy3 richy3 is offline
2002 GMC Envoy SLT
Black Granite Metallic 4.2L I6 4X4
temp sensor
Have had the same problem with my 2002 envoy. Went out and found the sensor where you all said it would be and shot it with a can of air and it has worked fine since. Thanks for your help !!!
  #26
Old 12-13-2007, 11:05 PM
drgonzo drgonzo is offline
2007 Chevy TrailBlazer LS
Silver 4.2L I6 4X4
I'll be doing this soon. Mirror should be here tomorrow. Did the dealership just have the parts on-hand or did they have to be ordered. Gmpartsdirect has the Sensor for 10.95 + another 10 for shipping.
Sorry to bump an old topic. Thanks to silverunicorn for pointing me in the right direction.
  #27
Old 12-14-2007, 08:32 AM
The dealer had everything I needed, but were really confused about the connectors to go into the wiring harness, which is why I got those elsewhere. I will send you some.
Don't forget, you need the sensor AND the connector for the sensor. I had to make 2 trips If I recall correctly, my sensor was $12 and the conenctor was $19. Pricey yes, but you can not do it without that connector.
  #28
Old 12-14-2007, 11:23 PM
Silver 4.2L I6 4X4
The link to the Delphi pdfs are down. When I go to the dealership, what part numbers should I give them. The sensor part number I've got, but for the connector???
  #29
Old 12-15-2007, 12:19 AM
mtt's Avatar
mtt mtt is offline
Sorry, I lost the part number. But I can tell you what to ask for, I didn't have a number when I went to get mine, either. The connector you are seeking is attached to a inexpensive sub-wire harness. When I bought my connector, it was listed in the documentation as an 'ambient air temperature sensor harness'. Yes, you need the connector for your air sensor. The matching connector to that comes with a pigtail harness. (It is sold with approximately 12 inches of wire already attached. This way, all you have to do is add more wire to lengthen it to get where you are going.)
When you attach the other end of these wires to the connector up on the fender, look back at the earlier posts in this thread. Those part numbers are what I used to get the correct parts (metripack connectors). All dealers keep a repair kit with these connectors. They are behind the counter and look like little compartmentalized bins like NAPA keeps o-rings and small parts in.
Do a search on metripack connectors so you can get an idea how they look when correctly installed. The cable seals are an essential part so they do not allow water infiltration into the connector. If you have any questions about it, just pm me. I'll be glad to answer any questions you have. My install turned out great, it looks more factory than factory does. I used wire loom to cover any exposed wire. Just look back at the earlier posts, there are some good tips there. Hang in there!!
  #30
Old 12-15-2007, 07:10 AM
Silver 4.2L I6 4X4
The connector description coupled with the sensor part number should do it.
Thanks
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Similar Threads
Remove alternator to change Thermostat? mastermonkhabib Engine Tunes/Mods 139 02-01-2018 01:19 AM
exterior temperature reading stuck redneckrod General 38 09-25-2012 09:19 AM
High Temperature Reading Kevin0475 General 6 06-12-2008 06:17 PM
PROBLEM WITH TEMPERATURE readings luilui8812 OEM Issues 5 06-06-2007 08:35 AM
External Temperature Gauge darkr182 General 5 06-30-2006 12:22 PM
