GWNF - Flag Pole Trail - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 General Tech Q&A > Off-Road
Off-Road For suspension, wheel, and tire questions DIRECTLY related to Off-Roading.
Old 11-23-2008, 10:17 PM
JamesDowning's Avatar
JamesDowning JamesDowning is offline
2005 Chevy TrailBlazer LT
Offroad Edition 4.2L I6 4X4
Well, I decided to do some recon out in the area of the GWNF (George Washington National Forest) that will be playing host to TECORE in April. I hit up a trail I had not gone on before, so naturally, it was quite an adventure.
I took a circuit that included an area called Flag Pole Knob and Meadow Knob which are both located along the Dundore and Richland Mountain Ridges. The highest elevation I reached was about 4,400 ft at Flagpole Knob. By the map below, I came into the forest on FR 225, and left via FR 227.
I posted up my GPS data on google maps. For some reason it put it in reverse order, so page 7 is the first leg of the trail. I think you can also view it all only in google earth, instead of in sections (seems to be a limitation of google maps).
So, here come the pictures...
This is near the entrance, where I decided to air down (I went down to 25 psi, which seems safe, yet greatly helps subdue the bumps):
The first major (at that point) hill climb. Plus it was the first snow I'd seen yet this year:
Where I pulled over to enjoy the view and have lunch:
On the north sides of the ridges, the snow lingered in greater amounts:
After this shot is where it got rougher. I had run across a little red Jeep JK (I think it was). He said he had not gone past this point (below) and that he thought it got really rough. I was determined to make it to Flag Pole Knob, so I pushed on.
Some of the rough areas I ran into. I think something may be wrong with my locker, because I was having a hard time getting it to engage when I needed it. Examples of when I needed it:
This is Meadow Knob. Quite a sight to see after trudging through the trail.
This is the trail from where I came:
Quite a steep hill climb. The snow made it especially fun, but low range had no trouble.
Flagpole Knob! The view was amazing. Almost a 360 degree view of spectacular mountains and valleys:
A panorama of the view:
I ran into one other truck up there. A Jeep Commander who had come up FR 227 to enjoy lunch on the Knob. He also had a 2" BDS spacer lift. We chatted a bunch about our trucks while going down the mountain (on the CB).
Ended up hitting a little bit of another trail with the same guy:
We ended the day with a nice frozen mud hole:
By this time it was about 5:30 and the sun was no longer on the horizon. So we decided to call it a day before we had only our headlights to guide us.
I aired back up and headed back home. Sorry, no video this time. I knew I was working with limited daylight, so I tried to keep up the pace. All in all, ~22 miles off the pavement... averaged ~8 mpg. (then hit about 17 mpg on the drive home).
Can't wait to bring some of you all along in April to show you all what your trucks are capable of!
... IF
you think you're ready...
Old 11-23-2008, 10:36 PM
ssmedt's Avatar
ssmedt ssmedt is offline
2004 Buick Rainier
Cashmere Metallic 4.2L I6 2WD
nice shots james; bet you guys are going to have a blast
Kevin
Old 11-24-2008, 12:16 AM
the roadie's Avatar
Great stuff !!!!!
That mud sure looked like partially melted chocolate ice cream.
As I remember when 4 Wheeler magazine built up a Commander, the best they could do with the BDS lift was 31's. But at least their spacer goes on TOP of the strut outside the spring so they don't lose articulation.
What I'm finding is on a lot of trails, 18 PSI gives me enough traction (if both rear tires are touching the ground) so the G80 never fires. But it's definitely worth checking out more. Do you recall it working for you before and how you modulated the throttle to reduce the impact forces?
Old 11-24-2008, 12:22 AM
Vartz04's Avatar
Vartz04 Vartz04 is offline
2008 Chevy Silverado W/T
Summit White 4.2L I6 2WD
looks like a great time, God i cannot wait to do some wheeling. I NEED TIRES.
2008 Silverado Regular Cab Long Bed 2wd 4.3 V6
RIP 2002 Trailblazer 4x4 I6
Old 11-24-2008, 12:28 AM
Originally Posted by the roadie View Post
Great stuff !!!!!
Haha, it was pretty soupy and nasty. I went through a river crossing later and that cleaned me off pretty well.
Yeah, their wheel wells are much tighter than ours. He said some guys had fit a 32" but it required excessive amounts of trimming.
I know it's worked before. It seemed to click in with only a little throttle. On two occasions today I got somewhat stuck. Gave it gas, and I neither heard the click, nor had luck getting traction. I tried two methods, low speed wheel turnage, and high speed burn rubber turnage... neither seemed to work. I may need to look into it a little more. They're kinda finicky it seems.
... IF
Old 11-24-2008, 12:47 AM
the roadie's Avatar
HAH! We're more modifiable than an XK!
...Gave it gas, and I neither heard the click, nor had luck getting traction..
Just to confirm, only one tire was spinning? If they're both spinning, of course - no way for the G80 to engage or assist. But you know that, so I shouldn't even ask.
Old 11-24-2008, 01:08 AM
battlemode's Avatar
battlemode battlemode is offline
2003 Chevy TrailBlazer LS
[QUOTE=the roadie;637250]As I remember when 4 Wheeler magazine built up a Commander, the best they could do with the BDS lift was 31's. But at least their spacer goes on TOP of the strut outside the spring so they don't lose articulation.QUOTE]
so do they have more articulation becas they dont have to compress the spring to put spacers in. all they have to do is put it on the top of the strut like the smaxx top spacer with the 2.5 lift kit. so if we can put that little spacer on top of our struts wy cant we make a kit that adds 2.5 inces on top of the strut. i do not know how the bds kit works but from what i understand it replaces the top peace on the strut with a spacer. or am i wrong. just trying to understant it a little more.. thanks.. oh and sory for a little..
sweet pics and wish i could drive down in april for the trip. but it would be somthing like 600 miles one way.. oh well
Old 11-24-2008, 01:22 AM
the roadie's Avatar
The SuspensionMAXX 2.5" kit has two pieces. One (1.4" thick) that preloads the spring and gives 1.75" of effective lift, but which doesn't lengthen the strut. And the other is 1/2" thick that goes on top of the strut and lengthens it and gives 3/4" of effective lift.
We can't make our strut any longer than 1/2" more than stock because of the way the upper ball joint angle is designed into the upper control arm. Makes it easier to lower the vehicles but harder to lift. Plus the inner CV joint starts to bind up at full strut extension.
The XK is designed differently, and is more like other vehicles, and you can add 2.5" or 3" spacer on top of the strut and things don't break.
The Canadian Ebay goofball who was selling that kind of mis-engineered death lift for trailblazers is off of Ebay now. He never replied to my emails, but at least I don't see his kit anymore.
Old 11-24-2008, 01:36 AM
battlemode's Avatar
i know whats thw smaxx kit is made up of. i was one of the first to have it on a tb on this site.. but i didnt even think of the ball joint problem.. darn gm.. now all we need is a company to rethink the upper control arms. oh well.. thanks for the clear up on the subject roadie. i think with time we will one day have the parts and companys backing us to reach higher levels. but that is all just wishing on a star for now.
Old 11-24-2008, 02:39 AM
lucky777 lucky777 is offline
2005 Chevy TrailBlazer LS EXT
Graphite Metallic 4.2L I6 2WD
Nice adventure. Pics are great.
Tags
gwnf, lifted, offroad, trail
