Quad Tail Lights? How-To Inside - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Appearance > Exterior
Exterior Exterior repairs/modifications
Old 01-05-2009, 09:57 PM
SportinLS2's Avatar
SportinLS2 SportinLS2 is offline
2006 Chevy TrailBlazer SS
Black 6.0L LS2 V8 AWD
Question Quad Tail Lights? How-To Inside
I was wondering if anyone has experimented with the curcuit boards in our taillight assemblies?
I had mine apart to replace a bulb and noticed ALL three sockets contain 3157 DOUBLE filament bulbs even though the top (brake/tail) in the only bulb that ever has both filiments powered.
The center bulb only uses the "bright" filament for turn signals and the bottom only uses the "bright" filament for back-up lights.
I was hoping someone with some electrical know-how might be able figure out how to make the center reflector (turn signal) also illuminate the "dim" filament to illuminate both red reflectors on each side to produce quad tails and leave the factory "bright" filament signal flash behavor of the center reflector.
Old 01-05-2009, 11:04 PM
PANGGOY's Avatar
PANGGOY PANGGOY is offline
2006 Chevy TrailBlazer LS
Silver Blue Metallic 4.2L I6 2WD
i tried this one before but after a few trial and errors i gave up.
i hope someone can figure this one out. i like the look of quad tail lights too
Once you go Glock, you don't go back...
Old 01-07-2009, 07:28 AM
csc06ss's Avatar
csc06ss csc06ss is offline
2006 SS Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 2WD
I've done it to mine. Its really pretty easy to do, but you will need to crack open the curcuit board to do it and then just run a couple of jumper wires. I did have to get another set of curcuit boards to rob a couple of parts out of them.
Now that I think about it, it took quite a bit of time to do, but it was worth it.
Scott
Old 01-07-2009, 07:30 AM
SilverUnicorn's Avatar
SilverUnicorn SilverUnicorn is offline
Scott
Details? Info? Pictures? YOU DID THIS???!!!!
If you can make a how-to that would be great!
[CENTER]
[/CENTER]
Old 01-07-2009, 03:55 PM
csc06ss's Avatar
I did it a long time ago and I didn't take any pics, but I'll see if I still have the old parts laying around here and if I do, then I'll try to put something together for you. It will take some time for me to do this, but keep after me and I'll get it done. You'll need a spare curcuit board to rob a couple of part out of. I've seen them on ebay for just a few $$$. See if you can get at least one of them for the mod!
Scott
Old 01-07-2009, 04:17 PM
trailrez trailrez is offline
2008 Chevy TrailBlazer LT
Moondust Metallic 4.2L I6 4X4
Nice mod I'd like to try...
Where is what does circutboard look like. I had my tail off yesterday briefly but all I noticed was a single plug. Im guessing the board is buried under the plastic, and you have to break it What part should I look for on ebay?
Old 01-07-2009, 07:04 PM
csc06ss's Avatar
The curcuit board is the part that the three light bulbs are in that screws to the back of the taillight. You will need to split it open to do the mod and then just glue it back together.
I just went to ebay and typed in "trailblazer taillight curcuit board" and they came up.
Scott
Old 01-07-2009, 08:11 PM
SportinLS2's Avatar
I thought that might be the case, so I already have one on the way just to peek inside.
You sure could save me some re-invention if you can remember what to do!
Drop me a reply if you need me to post a picture of a cracked open circuit board when my spare arrives. I really wouldn't want to see you break yours open trying to refresh your memory.
Also very nice to know this mod has some service life supporting it to be safe on the electrical system.
Old 01-07-2009, 08:27 PM
Stoli Stoli is offline
Do you have any pictures of the tail lights at night?
Old 01-07-2009, 08:48 PM
OffspringLTZ's Avatar
OffspringLTZ OffspringLTZ is offline
2002 Chevy TrailBlazer LTZ
Forest Green Metallic 4.2L I6 2WD
Yea i want to see some pictures of these bad boys in action too.
Here are some pics of a circuit board i took apart (from my 02TB)
The board went bad, had to replace it. Then used a flat head screw driver to pry it open. Real simple.
Here are some pics of my board
