Transfer Case Tech - The NVG 226 (NP8) Theory of Operation - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 General Tech Q&A > Off-Road
Off-Road For suspension, wheel, and tire questions DIRECTLY related to Off-Roading.
Old 03-05-2009, 07:37 PM
JamesDowning's Avatar
JamesDowning JamesDowning is offline
2005 Chevy TrailBlazer LT
Offroad Edition 4.2L I6 4X4
I figured I would share some of the great information found in the service manual concerning operation of the 4WD transfer case found in the Envoy and Trailblazer.
General Operation:
The New Venture Gear model NVG 226 transfer case is a two speed automatic, active, transfer case. It provides five modes of operation: Auto 4WD, 4 HI, 4 LO, 2 HI and Neutral.
The Auto 4WD position allows the capability of an active transfer case, which provides the benefits of on-demand torque biasing wet clutch and easy vehicle tuning through software calibrations. The software calibrations show more features such as flexible adapt ready position and clutch preload torque levels. The technology allows for vehicle speed dependent clutch torque levels to enhance the performance of the system. For example, the system is calibrated to provide 0-5 lb ft of clutch torque during low speed, low engine torque operation, and predetermined higher torque for 20mph and greater. This prevents crow-hop and binding at low speeds and provides higher torque biases at higher vehicle speeds, to enhance stability.
The NVG 226 requires no clutch shimming. the transfer case control module controls for the wear of the clutch and different clutch torque levels. The software learns adapt ready positions, which are for the correct clutch torque. The learned adapt ready positions vary as the unit wears over its life.
2WD
When the NVG 226 is in the 2 HI mode, the power flows from the transmission to the input shaft gear (1). The input shaft gear is connected to the rear output shaft (5) by the high/low range collar (2). The range collar inner teeth, high speed, are engaged with the input shaft gear (1) high speed position teeth. At the same time the range collar is slip splined to the rear output shaft (5). The rear output shaft delivers the power flow to the rear propshaft (6). The position of the control actuator lever shaft (8) allows no clutch engagement. The shift detent lever (7), which moves the shift rail and shift fork (10), is in the high speed position on the control actuator shaft (8).
4 HI and A4WD
In the 4 HI mode, the power flow to the rear propshaft is the same as in the 2 HI mode. To deliver power flow to the front propshaft during the 4 HI position, the transfer control module commands the encoder motor to apply the clutch to a calibrated torque. the encoder motor turns the control actuator lever shaft (8). A brake in the encoder motor holds the control actuator shaft in the full clutch position. The control actuator lever shaft (8) is cam designed and the cam action moves the clutch lever (4). The clutch lever (4) pivots on the control lever picot studs and moves towards the clutch apply plate, to engage the clutch. As more pressure is applied to the clutch apply plate, the clutch disks are compressed. Using inner clutch disks, which are engaged with the clutch hub (3), and the outer clutch disks, which are engaged with the clutch housing, the power flow is delivered to the clutch housing.
The clutch hub (3) is splined to the rear output shaft (5), and the clutch housing rotates on a needle bearing on the rear output shaft (5). The chain drive sprocket is splined to the clutch housing. The power flows from the drive sprocket, through the chain, to the chain driven sprocket. The driven sprocket is splined to the front output shaft (9). The power flow is delivered to the front propshaft through the front output shaft (9).
During the Auto 4WD mode, the power flow is the same as it is in the 4 HI mode. Except during the A4WD mode, the encoder motor rotates the control actuator shaft lever to the learned adapt ready positions. Rotating the control actuator to the carious positions changes the clutch torque level. When a differential of front propshaft and rear propshaft speed is recognized, the transfer case control modules commands for more, or less clutch torque.
4 LO
When shifting the transfer case to the 4 LO mode, it commands the encoder motor to turn the control actuator lever shaft (8) to move the shift detent lever (7), and to apply the clutch. The shift detent lever (7) moves the shift rail and the spring dampened shift fork (10). The shift fork (10) moves the high/low range collar (2) on the rear output shaft (5) splines toward the rear of the transfer case. The range collar (2) inner teeth, high speed, disengage from the input shaft gear (1) high speed teeth. The range collar (2) outer teeth, low speed, then engage in the planetary carrier teeth. The power flow is now from the input shaft (1) planetary teeth to the planetary gears in the carrier. Rotating the planetary gears, which are engaged in the annulus gear, the carrier rotates. The carrier, that is engaged to the range collar, then drives the rear output shaft. Therefore, providing a 2.69:1 reduction to the speed of the rear output shaft. The power flow to the front propshaft is the same as it is in the 4 HI mode.
A neutral position is obtained when the range collar is not engaged to the input shaft gear or the planetary carrier. Neutral position is used for towing the vehicle.
I hope this helps explain the transfer case internals. I wanted to share this excerpt with you because I found it extremely helpful in understanding how the NVG 226 internals operated! I'll also link to this thread from my site so it's easily located in the future.
... IF
you think you're ready...
Old 03-05-2009, 07:54 PM
lynch55's Avatar
lynch55 lynch55 is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 4X4
Thumbs up
I am lost---------wtf I'll leave that to someone else!
Old 03-05-2009, 08:06 PM
holmes holmes is offline
Graphite Metallic 4.2L I6 4X4
so whats the ideal mode (2hi or auto4x4)? what are the chances of blowing out the transfer case it auto if I am on a mixed road and the system kicks in and hits dry pavement? I have recently got the truck and my GF's dad and he said one time he heard a grinding noise in the front end when the auto4x4 was on but it was awhile ago I have not heard it since I have owned it. what do you guys think?
Old 03-05-2009, 08:07 PM
GeorgeJL75's Avatar
GeorgeJL75 GeorgeJL75 is offline
2003 Chevy TrailBlazer LS
Thanks for posting...that is excellent information! It's a shame the plant where all of our transfer cases were made is now closing. They have been turning out very high quality transfer cases for some time for many different auto manufacturers.
PCMFORLESS TUNED, K&N Gen II FIPK, HD Bilsteins
100,830 Miles
Old 03-09-2009, 05:29 PM
duneblazer's Avatar
duneblazer duneblazer is offline
2004 Chevy TrailBlazer LT
Onyx Black 4.2L I6 4X4
Thanks James.. you always get hold of very valuable information...
I have noted that the output for the rear shaft is 2.69:1 but the front is the same, interesting!!
Old 03-09-2009, 05:36 PM
the roadie's Avatar
The factory explanation is somewhat misleading. In 4WD LO range (and ONLY LO range), there is a 2.69-to-1 reduction gear as the transmission shaft enters the transfer case. Both front AND rear driveshafts are affected by this reduction. What the manual means to say is that the power flow to the front goes through the same path in 4HI as it does in 4LO.
Old 03-09-2009, 06:00 PM
Yep, as you can see, item number 2 in the pictures is the low gear spline selector. If that gear reduction wasn't ahead of the clutches for the front drive axle, the front wheels would turn at a different speed than the rear!
I did find it personally interesting that the clutch torque can be varied. So it will actually prevent crow-hopping when in A4WD. However, if you end up slipping the clutch when in that setting, it can throw more torque forward if necessary.
... IF
Old 03-09-2009, 07:24 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
I as well. When I read it, in the pdfs that roadie posted, I thought it was interesting that when 4AWD is selected, that 5 lbs torque is applied to the front wheels. Even if front traction is not required. Thanks James
Ray
Old 03-09-2009, 08:20 PM
Oops, I didn't realize I was reposting something. I should have known that the godfather had posted this information before.
... IF
Old 03-09-2009, 08:35 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
No, sorry. It wasn't a repost per-say. He posted a couple links that had similar info (probably from the same source)
I'll toss them in here
http://www.rsgear.com/articles/2003_01.pdf
http://www.rsgear.com/articles/2003_02.pdf
Believe me, with this topic it won't hurt to have it in a couple of threads.
Ray
