How do you set the front carrier bearing adjuster? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-13-2010, 02:10 PM
steveO steveO is offline
2002 GMC Envoy SLT
Black 4.2L I6 4X4
I marked the adjuster when I took it out.
I need to know if there is a procedure for setting it?
I had to replace the bearing cup.
Thanks!
Old 05-13-2010, 07:46 PM
2002 GMC Envoy SLT
Black 4.2L I6 4X4
Question about the front carrier bearing
It's pressed on correct?
The only way to replace it is to drop the Front Diff?
Old 05-15-2010, 10:06 AM
2002 GMC Envoy SLT
Black 4.2L I6 4X4
Picture of bad bearing cup Front Diff.
This is from the drivers side.
Inspected the bearing and it looked OK , not an easy thing to do.
When moving it by hand it was smooth. Since I can't get the carrier bearing out, I replaced the cup bearing.
Was cheap, $11.00 for entire bearing set from local auto parts store.
Click image for larger version
Old 07-12-2010, 12:26 PM
GarbeVic's Avatar
GarbeVic GarbeVic is offline
2002 Chevy Trailblazer LS, 110K miles
Blue 4.2L I6 4X4
Question for steveO: Did you ever find the procedure needed for adjusting your driver side bearing? I have not found it yet in this forum. I'm still searching...
Old 07-12-2010, 03:06 PM
2002 GMC Envoy SLT
Black 4.2L I6 4X4
Sorry I did not find this information.
I relied on recording the adjusters position and when I reinstalled the bearing cup I put it back to the same location as the previous.
It must be in the shop manual which I don't have.
Old 07-12-2010, 03:42 PM
GarbeVic's Avatar
Blue 4.2L I6 4X4
Thanks for the quick reply!
I plan to just install the new driver side diff. shaft seal (replacing mine because old seal was leaking a bit). I did not move the adjuster behind it. I marked the position with sharpie, then tried to rotate the adjuster with my finger. Since I could not move it, I will assume the adjuster did not move during or after seal removal.
Just to be sure we are talking about the same thing: I recently posted a photo of the driver side adjuster inside the diff. at the end of the following thread about seal removal:
https://forums.trailvoy.com/showthread.php?t=63915
Old 07-12-2010, 04:37 PM
2002 GMC Envoy SLT
Black 4.2L I6 4X4
Better yet I posted mine.
This is the drivers side
The first show the adjuster, with seal is removed.
The second is the adjuster removed and the bearing cup removed.
ID:	12595   Click image for larger version
Old 06-19-2011, 05:57 PM
MIGHTYM0USE MIGHTYM0USE is offline
2006 Chevy TrailBlazer SS (LS)
Silverstone Metallic 6.0L LS2 V8 AWD
hey so what was the resolution on this? i got the same thing im waiting on info for if you could hook me up i would appreciate it greatly as it would round off your informative thread nicely.
thanks
Old 06-19-2011, 07:02 PM
mattman396's Avatar
mattman396 mattman396 is offline
2003 Chevy TrailBlazer LS EXT
Summit White 4.2L I6 4X4
I did mine this spring, both carrier bearings were shot. it would be a compete waste of time only changing the one drivers side race, you need to pull the diff and do both bearings and seals, and maby even the pinion bearings, to set the carrier bearings it is a rotational torque of the input shaft. Doing that measures the proper preload, and if the one race is pitted those flakes are suspended in the oil and going through all the bearings and gears.
Old 06-19-2011, 08:35 PM
part numbers?
