Front Axle Seal? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-02-2012, 05:01 PM
bryanw80 bryanw80 is offline
2004 Chevy TrailBlazer LS EXT
Pewter Metallic 4.2L I6 4X4
Front Axle/Differential Seal New Part Number?
I have searched through several posts to find out the seal part number I need for my 2004 Trailblazer EXT 4wd. The seal I need is the front axle drivers side outer seal. The part number that always comes up in the searches is #12471618. When I went to the dealer and gave them that number they said it was an old number. He said that the new part number is #19257296? Can someone confirm that this is the new correct part number? Here is a picture of the seal that a need to replace:
https://forums.trailvoy.com/attachmen...7&d=1221967684
Thanks
Old 01-02-2012, 10:22 PM
matthewcc17 matthewcc17 is offline
2004 GMC Envoy SLE
Make sure its right. I did the work twice cause the dealer gave me the seal for the passenger side, which is smaller. Oh and i'd recommend doing all 3 on the front diff at the same time. Each time i did one the other went a couple months later. The seals are cheap and if you're doing the work yourself then you know if you get all 3 you will surely have the right one in hand.
Old 01-02-2012, 10:23 PM
That's why I am asking on here first. I called two dealers and they both said the same. I want to do this tomorrow but want to make sure I have the right part first?
Old 01-03-2012, 10:54 AM
TrailblazrI6 TrailblazrI6 is offline
Moderator
2002 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Somewhere around here, if you search, you will find the exact part number. Ive never replaced mine but I bookmarked it just in case.
Correction, I just found it by fishing through the thread. The drivers side outer differential seal is part #14271618 and a lot of useful info can be found Here.
Old 01-03-2012, 12:30 PM
Maybe you did not see the first post but I already stated that I had that part number from searching old post. That was not my question. Hopefully someone else can chime in, thanks
Old 01-03-2012, 01:09 PM
Moderator
Im sorry, I swore you asked somebody to confirm the new part number.
Old 01-03-2012, 03:13 PM
Yes, that is what I am asking. You just confirmed the old part number. Dealer said that the new part number is #19257296. I was hoping someone can confirm that this new part number has replaced the old part #12471618? Thanks
Old 01-03-2012, 04:35 PM
Moderator
http://www.gmpartsdirect.com/results...umber=12471618
It definitely looks like 19257296 replaced 12471618.
However, bringing either part # to the dealership will result in receiving the seal you need.
Old 01-11-2012, 01:36 PM
docneon's Avatar
docneon docneon is offline
2006 Chevy TrailBlazer LT
Factory Red/Sandstone 5.3L V8 4X4
I had to pick up a new seal from the dealer today. It had part #12471618 on the sticker and the invoice. Just FYI
Old 01-11-2012, 08:25 PM
Moderator
OP - you got your answer. Either part number works.
